0 members (), 186 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
Does any one know where to get the light bulb that goes into a signal stat turn signal switch, and indicates that the flashers are working? I think they call it the pilot bulb. It goes into the switch itself. Thanks, Terry
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics
Take the old one out than take it to a FLAPS and ask them to match it up,they also will have a book on bulbs.
Pete
In my Signal-Stat 900 switch they're the same as the bulbs for the AD high beam indicator lamp and ignition switch lamp.
I didn't open my SignalStat 900 to check, but BLUEMEANIE's info sounds correct.
6v = #51 Bulb
12v = #53 bulb
- Lonnie
My '54 3104
