7 members (moparguy, Chris_Welch, Gdads51, homer52, texas46, 2 invisible), 139 guests, and 4 robots.
Topics128,267
Posts1,058,386
Members48,485
#866176 07/11/2012 12:56 PM
Well here she is, picked her up in Feb, Trying to post picks, Shes all orig minus the 261 six, everything works too!. When I got here home I had to tinker right away,only had to change one tailight bulb, had her running about 20 min then all came to life! signals began to work,brake lights, ect. Even has the original keys. Anyone else own one of those "All in one" pump/valve/cylinder dumps like i have? photobucket
Nice truck always nice to see someone else with another dump truck!
Nice truck!
My dump isn't an "all in one" type unit - but a dump all the same. Mind you once it's back together I doubt it will dump another load in its life!
I just call it "all in on" unit. I can not find any tags on the piston to determine the make, If it was a conventional pto-pump-res-valve, I was going to tee off wet lines for a log splitter so i could split and through into the dump body.
My flatbed has a similar in concept setup. It has a shorter stroke though. Not sure on manufacturer..I think it says Sprague?? Steel Products, Inc. Before I found this 46 chevy, had been looking at 36 Dodge Dumper. Hoist Assy.
Moderated by  J Lucas
