7 members (Ponchogl, Otto Skorzeny, moparguy, KEVINSKI, Brian Moore, 55shaker, ShopRag),
71
Mod | | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 231 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 231 | Hey, My trucks a 53 sitting on a 1964 frame done by the previous owner. During the swap the po had to cut into the driver side fender to make room for the steering column and left a big hole. My question is, is their somewhere i could get some sort of thick rubber mat that i could attach to the iner fender to help fill the hole? Im not sure were to look for a 2'x2' sheet of rubber. | | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | a good farm supply store should have rubber belting for coveyors and such. or a farm truck shop
MO's 1951 chevy 3100 resto mod project
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Why not find a 2x2 piece of sheet metal and weld it into place or lap it and screw it in? It would be lighter and look better than a old rubber hanging there
| | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | McMaster, mud flaps from your local truck supply, etc. | | | | | Joined: Oct 2007 Posts: 231 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 231 | Thanks for the replys, the reason i figured rubber might look better is because of its flexibility.I go through the wheel well quite a bit to get to stuff and itd be easier to just fold it up then to unscrew it each time. plus im not sure how well i would be able to get the right bends in the metal to insure enough protection for the engine. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I use inner tube rubber for a lot of stuff, look for an old large truck tube, heavy but flexible
Bill | | | | | Joined: Mar 2012 Posts: 193 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 193 | Tractor trailer mud flaps work great for that kind of stuff as well. You can usually find them layin on the road after they fall of off trucks. Heavy duty, Can be cut with a utility knife and flexible too. I you buy them new, they cost between $7.00 and $16.0 depending on how long you get em. Brian
1952 GMC model 473 dump truck 1951 Chevy 1500 stepside
