| | | Forums66 Topics128,167 Posts1,057,096 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | Has anyone bought one of the kits from eBay from a place called Transparts? Are these a good kit and do they have all the parts you need to do a proper rebuild? Any suggestions of a good supplier of a good rebuild kit? John | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I hear Blumenthals Transmissions would have most of what you need. Look up there info on line and give them a call. Shop doing my rebuild needed a new cluster gear and Blumenthals had it new along with a low gear slide. | | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I just called Blumenthals about a cluster gear. You must have gotten the last one. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I just called Blumenthals about a cluster gear. You must have gotten the last one. | | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | Anaheim Gear should have one. 800-477-1103 I expect it will be pricy. Fred
| | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | I know Drivetrain in Las Vegas has them for just short of a hundred. Of course add in the flight, hotel, gambling, drinks and maybe a show...... I better call Anaheim. By the way, had a great St. Patty's day in Seal Beach a number of years ago. John | | |
