12 members (Paul_WNC, Wally / Montana, Woodcmiami, Joe H, baldeagle, tonyt, DannyW, Bill Hanlon, walter74, gswbbc, lumbersawyer, 1 invisible),
94
Mod | | | Forums66 Topics128,040 Posts1,055,475 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#86521 06/14/2004 5:43 PM | Joined: Jun 2002 Posts: 26 Junior Member | | Junior Member Joined: Jun 2002 Posts: 26 | I've got a '52 3600 Chev that's mostly original, with the exception of the main wiring harness. I've lost the horn operation just recently, and can't seem to restore it. I've dissembled the horn area for cleaning, and ended up replacing a good length of the original wire inside the steering column - thought that was it for sure as the original wire's casing was worn where it exits the column and strands were cut. Still nothing. Looking at one of the parts books, I found a horn relay for these years, problem is, I can't find one on my truck. Is there a horn relay switch on a '52 3600? I had a similar problem with my '69 Camaro, and found only an official AC/Delco horn relay made it work. thanks for any help! - rick | | |
#86522 06/15/2004 4:47 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | According to the wiring diagram in my 1948-1951 Chevrolet Truck Shop Manual the '50-'51 did not have a horn relay. The '52 supplement does not have a wiring diagram which indicates there were no changes. A hot wire runs from the + side of the ammeter to the horn. The ground wire runs to the horn button. | | |
#86523 06/15/2004 12:59 PM | Joined: Jun 2002 Posts: 26 Junior Member | | Junior Member Joined: Jun 2002 Posts: 26 | Thanks - that clears up that question! - rick | | |
#86524 06/15/2004 2:35 PM | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | The factory assembly manual shows a horn relay. Can anybody shed any further light on this subject? And as somebody mentioned above the wiring diagram does not indicate a horn relay. As my son would say: What's the deal......pickle? | | |
#86525 06/15/2004 3:36 PM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | The horns take a lot of juice and the wires to them on my '48 are big honkers (sorry). I'd be surprised if there isn't a relay somewhere. The little wires to your horn button are enough to throw the relay but it seems to me that they would burn up if they were used to power the horn. At least, that's the case on my '48. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#86526 06/15/2004 7:42 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | The relay should be right next to the little fuse holder with the plastic cover on the drivers side of the fire-wall in the engine compartment.
#86527 06/16/2004 7:34 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | rwise, even though the Factory Assembly manual reprint says 1947-1954, all the prints are for the 1954 model year. Check out the dates on them. The 1954 does have a horn relay. | | |
#86528 06/16/2004 1:17 PM | Joined: Jun 2002 Posts: 26 Junior Member | | Junior Member Joined: Jun 2002 Posts: 26 | Thanks for all the great additional info - I don't remember seeing a relay next to the fuse box on the firewall, but I'll certainly look again. All the wires look good otherwise. One thing my wife mentioned last night was she was occasionally getting shocked by the steering wheel if she pushed against it to get out (?) - could it be the horn's collar is grounding itself out? I took this collar off when replacing the wire coming from it, and inadvertently chipped away some of the insulative ring (?) between the contact & the steering wheel column. The problem occurred prior to my doing this though. - rick | | |
#86529 06/16/2004 1:18 PM | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | Thanks cletis. So I'm assuming from your previous post that the 49 did not use a horn relay? | | |
#86530 06/16/2004 4:49 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | My 51 has a horn relay, just under the dual horns, on the firewall, passenger side. The relay is powered directly and the input comes from the horn steering wheel switch, which is a switch to ground.
I believe that the relay was powered directly from the battery terminal on the starter and that is the way I have built the new harness. | | |
#86531 06/16/2004 11:15 PM | Joined: Jan 2004 Posts: 255 Member | | Member Joined: Jan 2004 Posts: 255 | rilap, There was a long discussion here on the bolt awhile back about getting shocked getting in and out of the stovebolts. The consensus was that it was static electricity from the seat covers and the type of cloth you wear. You may have a short, or it may just be your wifes shorts. Ralph | | |
#86532 06/17/2004 1:16 PM | Joined: Jun 2002 Posts: 26 Junior Member | | Junior Member Joined: Jun 2002 Posts: 26 | Thanks Ralph, I'm sure my wife will appreciate that! HA! I was wondering if it was due to the various cracks in the steering wheel, and the fact the horn collar is wired. With a passenger's side only exterior door lock, pushing off the steering wheel to get out is a pretty common occurrence. - rick | | |
