2 members (3B, Cosmo), 149 guests, and 3 robots.
Topics128,080
Posts1,055,951
Members48,430
#864571 07/05/2012 10:24 PM
Hello all, have been enjoying the posts but have not been able to work on my truck for a while. Finally got enough parts together to fire up my 383 sbc yesterday! Engine was built for a bracket racing car but I was assured in would be a streetable engine. I also purchased an Edelbrock tripower set up with early 2 barrel Rochesters, both guys said they would be around when I started it up. Fast forward 3 years, both guys are no longer in the area and I am trying to make this thing run. Engine cranked and fired right away on the center carb only. Got the timing set, adjusted the float for a slight flooding issue and went to adjust the idle mixture screws. From what I have read you start at 3 turns out and adjust to 2 to 1 1/2 turns. This thing wont even try to idle unless I am out 3 1/2 turns. The cam in this thing is a thumper, I dont think It wants to idle at less that 1000 RPM. Do the idle screws adjust fuel? is it OK to run them out for a high idle? I am currently using the choke cam to set the linkage up so it idles at 1000 RPM. Any input would be great. Thanks Boltbuster
45 Chev 1/2-ton (what's left)
Riding in the Passing Lane
If you have to run the idle jets rich like that you probably have a vacuum leak or your side carbs throttles are not closeing tight. Sounds like you have too much cam. Set the initial timing to about 12-14 degrees. Get a vacuum advance that comnes in at a low vacuum & hook the vacuum line to manifold vacuum.
1972 Chevy c10 Cheyenne Super
Carburetion specialist
The Carburetor Shop
Thanks Guys! The carb shop stuff is very helpfull. I sealed off the inlets to the out board carbs and got the idle adjusted pretty well. Only 6 lbs of vac. at 850 RPM, the cam is real lumpy. I drove it for the first time tonight, it runs pretty good! Got to sort out the steering and brakes. Thanks again
If you meant 6 inches of mercury at 850 RPM, I would highly suggest borrowing another vacuum gauge for comparison purposes!
Jon.
The Carburetor Shop
I'm tempted to give you the same advice the lady who had the 2-headed baby got- - - - -"You grew it, it's up to you to love it!" Any street engine with that much cam is going to be as irritating as a sandpaper girdle! Tripower carbs will simply add to the aggravation.
That is soooo true Hotrod! I am sure I will be installing a milder cam at some point. Fixed a couple of leaks and alinged the front end a bit more and took it out on the road. It pulls like a mule, 20 years ago I would have been grinning ear to ear but I am sure it will get old. Thanks for the input.
