Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (59 fleet, 78buckshot, Charles in CA), 190 guests, and 7 robots.
Topics128,282
Posts1,058,497
Members48,490
#864196 07/04/2012 6:26 AM
So i am rebuilding my 61 235 and this is my first rebuild ever.... so as you can guess i lost the bolts for the camshaft thruster plate that connect to the block. I have the Detroit Iron Works Manual from LMC and they give me the bolt size 1/4 20 x 3/4 . This is dimensions for a 63-65 L6. Is this the right sized bolt i need to try to find? Thanks a bunch!
- Theres no replacement for displacement.
Correct - they are Phillips head 1/4"-20 x 3/4".
Thanks!
