1 members (dt235sd),
101
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 20 New Guy | | New Guy Joined: Dec 2009 Posts: 20 | Howdy all, I have a '71 Chevy K10 with a '67 283 in it that I just finished putting heads and an intake on. However, my spark is very weak, so I can't get it to start up, it sputters and tries to start, but just can't get going. Anyways, I was pulling my distributor out to verify my timing, with is just the stock Delco distributor with an Ignitor II module to replace the points. When I got the gear up out of the manifold, I accidentally bumped it against the intake, and much to my surprise a blue arc of electricity arced from the dist. to the intake. Needless to say, I was pretty sure that was not kosher. I checked the wiring on the Ignitor to make sure it wasn't worn through, and I couldn't find anything. Can this module go bad and short out or could something else in the distributor be causing this short? Thanks in advance.
Si '71 Chevy K10 '78 GMC K25
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | did it start ok before you installed heads and intake Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Feb 2004 Posts: 29,947 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,947 | Did you forget to turn the ignition off before you removed the distributor? I've had students experience major crankcase explosions from yanking a distributor out of a flooded engine after forgetting to switch off before removing it. Jerry
| | | | | Joined: Dec 2009 Posts: 20 New Guy | | New Guy Joined: Dec 2009 Posts: 20 | Thanks for the replies, fellas. Joker, it ran like a top before I put the heads and intake on, they were just from a smogger 305, so I replaced them w/ 1.94 valve double hump heads and a weiand dual-plane intake. Hotrod, the ignition switch was off, but the battery was still hooked up. I'm gonna check the wiring from the Ignitor II module again to make sure its not worn through; this one has me puzzled.
| | | | | Joined: Feb 2004 Posts: 29,947 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,947 | You have reduced your compression considerably with the camel hump heads. They're 64 CC's, and the heads you removed were probably 58 CC units. The 283 doesn't need 1.94" valves unless you're planning to spend a lot of time above 6,000 RPM. The low-end torque will just about go away with that setup, and a 283 has very little torque to begin with.
It sounds like there's a capacitor somewhere in the ignition system that's got an open bleeder resistor, and it's staying charged after the ignition switch is turned off. You'll probably need to get a warranty replacement on the ignitor, or use a regular GM HEI unit instead of trying to modify the original distributor. Jerry
| | | | | Joined: Dec 2009 Posts: 20 New Guy | | New Guy Joined: Dec 2009 Posts: 20 | Thanks for the help Hotrod, it is much appreciated.
| | | | | Joined: Feb 2004 Posts: 29,947 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,947 | Here's a very handy chart I use to help in head selection. There's a couple of 57-58 CC 305 heads available that respond very well to porting and larger valves if you're planning to build a full-race engine. Otherwise, just do a good cleanup/deburr job on the stock head and stick with the original valve size. http://www.fastnuf.com/Headguide.htmlJerry
