6 members (Otto Skorzeny, Charles in CA, DadsFirstPickup, J Lucas, Shade Baby, greenie-reddy), 112 guests, and 1 robot.
Topics128,147
Posts1,056,798
Members48,454
#863186 06/30/2012 3:35 AM
I am getting a 1954 235 full pressure oiler for my 48 Suburban. My Suburban was delivered with no transmission or bell. There is a Craigs List seller in my town selling a 47 truck 3 speed transmission. Will it work with the 235?
1947 three speeds were floor shift and the trans is shorter.
If the torque tube comes with it it will fit. The 47 torque tube is longer to make up for the shorter trans.
1948-54 will be a direct fit.
My Blog
If you use the 1947 torque-tube rear-end, it has a 4:11:1 ratio. The 1954 rear end has a 3.90:1 ratio.
One advantage of the 4:11 rear end is that the ring gear carrier works with the 3.55 ring and pinion conversion (if you ever want to o the conversion). An earlier carrier can be used in the 1954 3.90 rear end, if you want to do the 3.55 conversion
Interesting. Thankfully the transmission is in my same small town so I will check it. He lists it as a 47.
