| | | Forums66 Topics128,020 Posts1,055,345 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 60 | I have a question,about my 58 Apache,1/2ton,stepside. The previous has a 77 4WD,setup on it now with a lift kit. It looks good but,to high for my preference. What year truck,could I use to get my truck back down to a factory level? And also do away with the 8lug wheels. Thanks,any help,and experience,would be appreciated.Thanks! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | a 58 or 59 Chev truck chassis would be an appropriate choice, an easy fit if the PO didn't hack things up too much, and restore it to the proper 6 lugs .... 55 2nd to 57 could be made to work as well, but you have to add an inch or so to the front frame horns
Bill | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | If it's too high for your preference, will taking out the lift kit bring it back to the altitude you desire? | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Do you want it to be a 4x4? If so, just buy the original springs for a 77 4x4, that should drop it back down. If you want a 2wd, find a 58 3100 chassis.
Any pictures? | | |
