BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
8 members (klhansen, Lightholder's Dad, Ridgeback, qdub, Steelonsteel, joetravjr, mick53, 1 invisible),
561
robot. | Key: Admin,
Mod | | Forums66 Topics126,780 Posts1,039,291 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Apr 2012 Posts: 17 New Guy | New Guy Joined: Apr 2012 Posts: 17 | I'm going to put original 16" steel rims back on my 1948 Chevy 1/2 ton. Can anybody tell me what size radial tires will fit on 16" x (5.5"?) rims and come close to the diameter of the stock bias-ply tires? | | | | Joined: Apr 2009 Posts: 554 'Bolter | 'Bolter Joined: Apr 2009 Posts: 554 | 215x85x16 is the closest modern size you will find. Coker tire does offer a 600 or a 6.50x16 radial that is very close to the profile of a similar bias ply tire is is the same size.
Chuck | | | | Joined: Aug 2005 Posts: 6,383 Ex Hall Monitor | Ex Hall Monitor Joined: Aug 2005 Posts: 6,383 | Diamondback tires offers a 195/80/16 white or black which is about the closest you'll find domestically. The cross section is quite a bit wider than the 600x16 but unless you buy Coker's classic bias or radial it's the best you'll do. <PAGE 22> In Europe you can get a 185/85/16 that is closer still but still a wider cross section.
