1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#843707 04/14/2012 4:31 AM
I wasn't sure where to post this so I decided to post it here. I have a 250ci in my 38 GMC that I want to put Langdon headers on But don't have the money, anyway I was checking ebay out and found this http://www.ebay.com/itm/320805012222?_trksid=p5197.c0.m619#ht_500wt_1048 thought it was cool. I think I am going to give it a try and see what happens.
1938 Gmc 1/2 ton
It works...Gets the job done..I got it on my '47 coupe...Doesn't look too hokey...It WILL take longer warm-up time though, losing that heat-riser , not good...
mo Offline
theres an old timer my way that splits exhaust all the time. it works. mo
MO's 1951 chevy 3100 resto mod project
The whole point of a split manifold is to keep the heat riser intact to maintain cold start driveability. $40.00 for an elbow with no studs or bevel seems a bit steep to me as a 2" gasfitters elbow will work better and set you back about $3.00. Pre and post heat are the key to success when welding cast iron and I compiled what I did here.
You Tube
Curt Thanks for the info I like $3bucks even more then the $40, I will have to find a gasfitters elbow now. I also like your documenting how it is done.
Where do you get a 2" gas fitters elbow ?
1938 Gmc 1/2 ton
Your local Plumbing Supply house will have them...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
1 Offline
I still see GM Chevy Corvette six and Repop split manifolds at the Swap Meets. The last one I saw still had the GM parts tag on it help by a thin wire. That one had the heat riser in it. Split manifolds work fine and if you can keep the heat riser, even better.
Normbc9
