5 members (3800GUY, FAST55, wilbur53, Jon G, Otto Skorzeny), 190 guests, and 0 robots.
Topics128,104
Posts1,056,201
Members48,436
#862711 06/28/2012 1:01 PM
3 Online: Content
I am trying to get my 1946 3/4 ton going which has sat for several years. It has the original 216 motor in it and it ran until I quit using it. I currently have the oil pan off and the head off for some minor repair. The engine is free and everything turns fine. However, for not being used for a while, the cam shaft has some tiny spots of rust on the suface where the lifters ride. Does this mean the cam is toast? Should I replace before trying to start it. or will these spots wear off with the motor running?
3800GUY #862726 06/28/2012 1:52 PM
You could try lightly polishing the lopes, but if the rust is too deep I would replace it.
Drew
3800GUY #862761 06/28/2012 3:35 PM
Don't worry about it unless there appears to be deep pits. Minor surface rust will polish itself away with a few minutes' running time. Look at a disc brake rotor after just a few days of non-use. The cam lobes are constantly bathed in splash oil from the crankshaft and rods, so slight surface rust will disappear even faster than a brake self-polishes.
No sweat.
Likely it's just minor.
And will go away very quickly.
You might think about changing the oil after a couple hundred miles just to get any junk out of it.
Jeremy
1950 Chevy 3800 1-Ton Long Bed
More pix on Flickr
Sold all the bikes, leaving California behind.
