1 members (texczech),
51
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 152 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 152 | I bought a harness from classic parts I'm pretty pleased with it but I have a few questions. Is the positive post on the discharge side or the charging side of the ampmeter? And when hooking up accesories do you go to the ignition switch, or the positve post on the ampmeter? My instructions from classic parts say hook the flasher to the amp meter, but that would let them run when the ignition swith is off. Any help would be greatly appreciated. Thank you, Terry
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Do you have a Shop Manual for your truck (1949)? There is a wiring diagram in it. The on-line manual's page is hard to read. Different accessories connect to different sources: ignition switch, ammeter, fuse box. | | | | | Joined: Jan 2011 Posts: 152 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 152 | What I need to hook up are the radio, Heater, and turn signals.
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I'd want the turn signals to work with the ignition off, allows for roadside emergency lights, and if they were hooked to the ammeter or light switch [same thing] that'd do it - the radio and heater should be from fuses powered by the accessory terminal of the ignition switch, off with the switch
Bill | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | I don't have hazard lights but my signals are hooked up originally to work with the truck off. | | |
