3 members (2-Ton, Mike B, 1 invisible), 69 guests, and 2 robots.
Topics128,030
Posts1,055,419
Members48,422
#862587 06/28/2012 1:11 AM
I bought a harness from classic parts I'm pretty pleased with it but I have a few questions. Is the positive post on the discharge side or the charging side of the ampmeter? And when hooking up accesories do you go to the ignition switch, or the positve post on the ampmeter? My instructions from classic parts say hook the flasher to the amp meter, but that would let them run when the ignition swith is off. Any help would be greatly appreciated. Thank you, Terry
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics
Do you have a Shop Manual for your truck (1949)? There is a wiring diagram in it. The on-line manual's page is hard to read.
Different accessories connect to different sources: ignition switch, ammeter, fuse box.
Terry,
List the accessories and people will tell you where the get power.
Here is an accessory installation manual - 1951.
Some accessories attach to the light switch.
Someone else will have to give info on the ammeter posts.
What I need to hook up are the radio, Heater, and turn signals.
I'd want the turn signals to work with the ignition off, allows for roadside emergency lights, and if they were hooked to the ammeter or light switch [same thing] that'd do it - the radio and heater should be from fuses powered by the accessory terminal of the ignition switch, off with the switch
I don't have hazard lights but my signals are hooked up originally to work with the truck off.
