9 members (Cosmo, VicZ, Patina 54, Wally / Montana, Mike Burns, Ponchogl, HandyAndy, 2 invisible),
191
0
Mod | | | Forums66 Topics128,087 Posts1,055,977 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 44 New Guy | | New Guy Joined: Jun 2012 Posts: 44 | My son just purchased a 1953 gmc with a 6 volt spotlight. We changed it to 12 volt and need a 12 volt bulb for the spotlight. Does anyone know where we can order one. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy jdzcno, welcome, if you tell us the number on the bulb, we may be able to identify a compatable twelve volt replacement. | | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 | Just one place www.unityusa.com to look.
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. -Unknown-
| | | | | Joined: Jun 2012 Posts: 44 New Guy | | New Guy Joined: Jun 2012 Posts: 44 | The only markings on the light are sealed B-L-C spot. There are no other markings. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Is this a picture of your 6v bulb?See the first listing under "Fog & Driving Sealed Beam 6-8 Volt Light Bulbs" at taillightking.com Perhaps he can find a 12v bulb. I looked for one at donsbulbs.com, but did not have enough info. The only BLC listed at Don's is 130volt. Might keep an eye on this thread on VCCA. Similar question to yours.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Jun 2012 Posts: 44 New Guy | | New Guy Joined: Jun 2012 Posts: 44 | It is the same except for the little plate and screw. They are not on ours. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | The pic was on the page that I linked to on taillightking <dot> com. Looks like the center screw connects to a terminal on the end of the hot wire. And the outer screw connects to ground. Call the guys at "taillight" and at "unity" to discuss and find a 12v substitute.
Not sure if hi-beam sealed beam quad headlight were 5-1/2" diam or 5-3/4" diam. It's not ideal, but you might be able to use push-on spade terminals to adapt one to your spotlight if there is enough space in the housing. Watch for high current draw.
