| | | Forums66 Topics128,074 Posts1,055,911 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#86189 07/15/2002 6:13 PM | Joined: Feb 2000 Posts: 177 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 177 | Ok, Had a generator (long) and used it since 1995. It's dead dead dead. So anyway I've had it out rebuilt it, everything except windings. I noticed it's stamped 12V on the case. My system is 6 volt. So maybe the case was off a 12 volt? Maybe the whole generator is a 12 volt? The voltage regulator is 6 volts for sure. So here's my stupid question can I use a 12 Volt generator in a 6 volt system? Gracias in Advance, Kip
Write On The Cross At The Head Of My Grave To Whiskey And Women Here Lies A Poor Slave
#86190 07/15/2002 7:04 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Yes, you can,,,,,,just be prepared to replace the 6-volt components as they BLOW-UP  :p
#86191 07/15/2002 9:48 PM | Joined: Feb 2000 Posts: 177 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 177 | Ok so I put a 6 volt and a 12 volt generator side by side. What's different, the number of armature windings? the two field coil jobs bolted to the case? Adios, Kip
