0 members (), 54 guests, and 3 robots.
Topics128,072
Posts1,055,906
Members48,429
#86189 07/15/2002 6:13 PM
Kip
Offline
Ok, Had a generator (long) and used it since 1995. It's dead dead dead. So anyway I've had it out rebuilt it, everything except windings. I noticed it's stamped 12V on the case. My system is 6 volt. So maybe the case was off a 12 volt? Maybe the whole generator is a 12 volt? The voltage regulator is 6 volts for sure. So here's my stupid question can I use a 12 Volt generator in a 6 volt system?
Gracias in Advance, Kip
Write On The Cross At The Head Of My Grave
To Whiskey And Women Here Lies A Poor Slave
Yes, you can,,,,,,just be prepared to replace the 6-volt components as they BLOW-UP eek grin :p
Kip
Offline
Ok so I put a 6 volt and a 12 volt generator side by side. What's different, the number of armature windings? the two field coil jobs bolted to the case?
Adios, Kip
