9 members (2-Ton, DadsFirstPickup, 32Fordpuchoptop, FAST55, Otto Skorzeny, mason86, rfs56trk, TexasJim50, Forty9),
102
Mod | | | Forums66 Topics128,049 Posts1,055,661 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | The brake light on the passenger side of my 1965 C20 is not working but the tail light and directional are. I installed a new bulb but that was not it. I consulted my shop manual but it did not seem to address this problem. The low beam on the passenger side headlight is also not working. Could they be related? Any advice would be much appreciated. Thanks.
1965 Chevy C20 Stepside
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I would take a test light and have someone step on the brakes with the probes on the brake light contact. If the test light works it's a bulb, if not start working your way up the 'chain'.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Cape65C20, the brake light feed must pass through the turn signal switch, but as Tiny said start at the bulb socket and work your way back towards the switch. I doubt very much that the headlight problem is in any way related to the brake light problem. | | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | Thank you both. I will start there.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | A test light at the brake light with one probe to a separate ground would be very useful. Some grounding problems cause very strange symptoms and at times they don't appear logical. | | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | You are so right. Thanks.
