5 members (Guitplayer, tclederman, Leo, stlcardinalsguy, FAST55), 65 guests, and 2 robots.
Topics128,050
Posts1,055,673
#861599 06/24/2012 12:19 PM
The brake light on the passenger side of my 1965 C20 is not working but the tail light and directional are. I installed a new bulb but that was not it. I consulted my shop manual but it did not seem to address this problem. The low beam on the passenger side headlight is also not working. Could they be related? Any advice would be much appreciated. Thanks.
1965 Chevy C20 Stepside
Ex Hall Monitor
Ex Hall Monitor
I would take a test light and have someone step on the brakes with the probes on the brake light contact. If the test light works it's a bulb, if not start working your way up the 'chain'.
3B Offline
Hy Cape65C20, the brake light feed must pass through the turn signal switch, but as Tiny said start at the bulb socket and work your way back towards the switch. I doubt very much that the headlight problem is in any way related to the brake light problem.
Thank you both. I will start there.
A test light at the brake light with one probe to a separate ground would be very useful. Some grounding problems cause very strange symptoms and at times they don't appear logical.
1951 1 Ton Completed
You are so right. Thanks.
