11 members (klhansen, cmayna, Hotrod Lincoln, Peggy M, Wayne67vert, 52Carl, Forty9, walter74, HandyAndy, 2 invisible),
142
Mod | | | Forums66 Topics128,114 Posts1,056,282 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 17 New Guy | | New Guy Joined: Jun 2012 Posts: 17 | So my '79 C10 has dual gas tanks in the rear on each side and we want to replace them with a fuel cell, but I don't want to lose all that gas capacity. Am I going to be able to reasonably get somewhere near as much gas? And are the gas tanks really as much a safety issue as my dad says?
All in favor, say I. All opposed, Shutup
| | | | | Joined: Jun 2012 Posts: 17 New Guy | | New Guy Joined: Jun 2012 Posts: 17 | Im not a reckless driver, but if i were to ever get in one (knock on wood), i would want something thats not going to blow up and kill everyone involved. Thanks man
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I would leave the stock tanks, unless you're planning of racing or hard core off roading. They built millions of those trucks with the tanks on the sides, many are still on the road. It's been proven that the tanks will not "explode" in a side impact. NBC got busted pretty bad over that one, as they got caught using model rocket engines to make the feul in the tank to light off in their "test".
Bill Burmeister | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | As Mr Lang suggested, have a look at Summit or Jegs. You can get cells up to 20 gallons, in varying sizes and configurations. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | If you decide to get one, aluminum is the way to go. I put a plastic fuel cell in a 68 Mustang for a man who was concerned about safety when his toddler daughter was riding in the car, and we had to go back in and redesign things. The tank would warp in hot weather, so we ended up fabricating a sheet metal box to support it. Fuel capacity isn't a problem as long as you've got enough room to mount a big enough tank. Jerry
