8 members (Tyler Watts, Hotrod Lincoln, Joe H, Gray_Ghost, Forty9, cmayna, JW51, NJC),
82
Mod | | | Forums66 Topics128,064 Posts1,055,860 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#86136 03/10/2003 2:32 PM | Joined: Jun 2002 Posts: 26 Junior Member | | Junior Member Joined: Jun 2002 Posts: 26 | We've got a directional signal with a small light bulb at the end of the lever to remind the signal's on. Its pretty worn, and is getting finicky. There are 7 or 8 wires coming from it. Anybody know where another of this type can be purchased? I've not found one with the end bulb. thanks - rick | | |
#86137 03/11/2003 12:41 AM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Look on eBay. I've seen a lot of those. | | |
#86138 03/11/2003 6:39 PM | Joined: Jun 2002 Posts: 26 Junior Member | | Junior Member Joined: Jun 2002 Posts: 26 | Thanks - I'll take a look. - rick | | |
#86139 03/11/2003 6:56 PM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Check the vendors listed here. Most have the same one, some have two kinds. NAPA has a cheap one and a better one, but that one's $60 or so, I didn't see the advantage to it, plus it had a short plasic lever and black case, didn't look as nice. I prefer the metal/chrome ones most have. should only be about $25. Make sure you get a seven wire one or it won't work signals and brakes on same lights. The five wire ones, need a seperate lite for signals. Check around some of the trailer lights and acc. in auto stores for the switch, it's a bottom shelf part!!!
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
#86140 03/12/2003 7:08 PM | Joined: Jun 2002 Posts: 26 Junior Member | | Junior Member Joined: Jun 2002 Posts: 26 | Thanks for the extra tips - I've got a NAPA just down the street, but never thought of asking for this item. - rick | | |
#86141 03/14/2003 3:16 PM | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | Signal Stat 900 for $5 SAME Signal Stat 900 for $40! Pick which one you want. They both have blinker indicators for the directional on (red "V" lens in center). They are identical switches except one is 10 times the price of the other. They are both on eBay. Ooo! Here's the one you have now (I presume) but this one is NOS in the original box! This to me is a good deal. NOS ->Signal Stat 800 Directional Kit w/flasher | | |
#86142 03/17/2003 9:13 PM | Joined: Jan 2001 Posts: 230 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 230 | Wow , that's _CHEAP!_ . too bad I allready have a newer one hard wired in my truck .
-Nate There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
#86143 03/17/2003 10:38 PM | Joined: Jun 2002 Posts: 26 Junior Member | | Junior Member Joined: Jun 2002 Posts: 26 | Interesting - thanks. Stopped by NAPA - they have no clue: "we only have replacement parts". - rick | | |
