| | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: May 2012 Posts: 37 | Thanks for the heads up on the seat base while using some aftermarket seats from another thread. I have seen it done both ways in various other models and configurations.
My question is: Will we have to remove the original (existing) seat base in total before we install replacement (Buick) seats? Or would we install the replacement seats on to of the existing base?
Our seat base got welded in at some point, and I don't want to start cutting if I don't have to. | | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | That was me (or at least I was one of them) that posted about leaving in the seat riser. I got some 2000 Buick LeSabre seats and they fit without the riser, but I have to raise them all the way up (they are powered seats). If I had left the riser, I could have used them in the lowered position and still had room for a shorter driver to raise the seats.
Craig
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
| | | | | Joined: May 2012 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: May 2012 Posts: 37 | Thanks, Craig! That was exactly what I needed to know. We are currently searching for the 20XX year model seats, and just wanted to make sure before we got too far into it.
Thanks for the follow up! | | |
