4 members (Bills Auto Works, moparguy, Southerntruck, Napco Man), 118 guests, and 2 robots.
Topics128,049
Posts1,055,680
#861056 06/22/2012 2:02 AM
I am replacing a new gas tank and as I take it off I find out I need a sending unit also,can I put the gas tank on without the sending unit?
61chevygal #861060 06/22/2012 2:09 AM
if you can still get at the hole to install a sender later, sure .... what year truck? where's the tank? do you plan on putting gas in it without the sender? if you mean can you use the tank without the sender installed ..... really?
61chevygal #861081 06/22/2012 3:14 AM
Assume you mean the sender (float, resistor, etc & not the sending unint asm.
Do you need to replace it because you have aftermarket fuel gauge or is it rotted off? If just the gauge, go for it, don't let it run out!
BC
1960 C60 pasture art
61chevygal #861122 06/22/2012 6:14 AM
I bought the gas tank from E-Bay for a 1964 chevy Belair,
ebay
61chevygal #861125 06/22/2012 6:42 AM
that link is for a sender ... you're buying that for the tank you already bought? the tank is going under a 64 BelAir? looks like the sender goes in the side, you might be able to fit the sender in after the tank is in, but it'd likely be easier before installing the tank, might be stuff in the way after
