| | | Forums66 Topics128,052 Posts1,055,719 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 10 New Guy | | New Guy Joined: Jul 2009 Posts: 10 | I am replacing a new gas tank and as I take it off I find out I need a sending unit also,can I put the gas tank on without the sending unit? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if you can still get at the hole to install a sender later, sure .... what year truck? where's the tank? do you plan on putting gas in it without the sender? if you mean can you use the tank without the sender installed ..... really?
Bill | | | | | Joined: Sep 2011 Posts: 1,453 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,453 | I am replacing a new gas tank and as I take it off I find out I need a sending unit also,can I put the gas tank on without the sending unit? Assume you mean the sender (float, resistor, etc & not the sending unint asm. Do you need to replace it because you have aftermarket fuel gauge or is it rotted off? If just the gauge, go for it, don't let it run out!
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jul 2009 Posts: 10 New Guy | | New Guy Joined: Jul 2009 Posts: 10 | I bought the gas tank from E-Bay for a 1964 chevy Belair, ebay | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | that link is for a sender ... you're buying that for the tank you already bought? the tank is going under a 64 BelAir? looks like the sender goes in the side, you might be able to fit the sender in after the tank is in, but it'd likely be easier before installing the tank, might be stuff in the way after
Bill | | |
