| | | Forums66 Topics128,088 Posts1,056,381 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 197 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 197 | I rebuilt the master on my '65 and it leaked. Took it apart and found out the rear (outermost) piston cup seal just slipped on over the aluminum piston loosely. The brakes were fine but it leaked fluid out of the boot onto the firewall, maybe 1/8" of the reservoir level a day.
Anyway, I guess the moral is ALWAYS check Chinese crap well before installation, and avoid it if ya' can. Now I have to go buy another kit and put it back together. And the brake fluid also ate some paint off the firewall. Nice.
-Chaz
Some of my crap: 1963 C-30 flatbed dually 292/SM420 1965 C-10 LWB fleet 250/column shift 3 speed 1965 C-30 9' stepside 250/SM420/4.10 gears (my DD) Website I made for my crap: http://www.66submarine.com | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i'm sure you checked to make sure it's not backwards. wouldn't think it could slip much as long as it is the correct bore rubber cup and the bore isn't too wore. i do hate those tapered pig tail type springs they include anymore, the ends aren't as wide as originals. | | | | | Joined: Jun 2012 Posts: 197 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 197 | It isn't loose in the bore, it's loose on the aluminum piston it fits on/over, and leaks between the two. It's the seal on the piston closest to where the master cylinder bolts to the firewall.
