8 members (cmayna, 46 Texaco, UtahYork, TUTS 59, jmoore, EchoBravoSierra, Otto Skorzeny, TexasA&M48Truck),
87
Mod | | | Forums66 Topics128,202 Posts1,057,409 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#86065 05/19/2002 1:24 AM | Joined: Jan 2002 Posts: 24 Junior Member | | Junior Member Joined: Jan 2002 Posts: 24 | i changed complete wireing harnees on my 66 c10 from the doner 1981 but i can't figure out the headlights.. the 81 truck i got the harness and wireing from had 4 headlights 2 .but my 66 c10 only has 2 headlights how do imake this work.if you have done this or know someone who has help please. | | |
#86066 05/19/2002 3:54 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | I believe the wire harness has two plugs on each side.The three hole plug is for the high/low beam lights and the two hole plugs are for high only. .You may be able to use the two hole plugs for some driving lights!
