2 members (Ponchogl, Hush),
67
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Is this the one needed for a 261 to V8 conversion with a SM420 in the truck ? I think about buying one, not this one, just in case since the old 261 behaves a bit odd. And if I see it has a blown head gasket it will go out at least temporarily. And while a rebuild I thought this could be a way to go. http://www.ebay.com/itm/1955-1956-1...ries&hash=item3a76085904&vxp=mtrBUT, with this bellhousing a 265 and a 283 will be the only choice ? IS there any options for putting a 350 in ? Since they are more than common and easy to find a used one for no money. My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | That one will bolt up to any Chevy V8, small or big block, and all the 2nd.-generation sixes, 194, 230, 250, and 292. It will need the 3-bolt starter that bolts to the bellhousing, not the engine block and a large-diameter flywheel (don't remember the tooth count offhand).
You might have to fabricate front motor mounts and clutch linkage to make everything work, plus the exhaust system. As long as you don't go too big on the engine size, the radiator you have now should work OK. A 396, 427, or 454 might require more cooling, but up to a 350 should be OK. Jerry
| | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | Ulf, As HL said any SBC will bolt right in. I have a 350 in my 1956 Tow Truck and it runs great. You will need the V8 motor mounts sold by all of the vendors (same as the pickup trucks). The clutch linkage will work, it might need to be adjusted a little and you'll need the V8 throttle linkage. The radiator will need to be moved back about 5" or you'll need a deep fan shroud. You also need to change the ignition switch to one that has the "start" position as you will loose the foot start when you convert. The rest is just normal re-working the electric, exhaust, vacuum and fuel lines. You will be happy with a 350...lots of power and faster speed. The Bell Housing will need the dust shield (two pieces, bottom and front). Mike B  | | |
