0 members (), 125 guests, and 10 robots.
Topics128,186
Posts1,057,211
Members48,465
I have a '51, 1/2 ton, and am setting up for street ride. It has a 216 engine, and just bought an '85 Camaro T5 trans with 0.76 5th gear for $75.
I just found an '86 Camaro rear with a 3.23. When I run the rpm calculator, at 65 mph, I get about 1980 rpm. I can probably get the axle for about $125. Is this a good fit or should I keep looking for a different axle/gear to get me closer to 2200 rpms?
thanks
1951 Chevy 3100
Generally that's a good match. Some use a 3:55 rear. I would be concerned that your 216 could handle a constant 2K rpm, although
I really don't know for sure. Maybe others here do. It just wasn't built for that continuos strain, just really more low end easy running. In any case, if you do want to run at 65mph, you better upgrade to better brakes and rebuild the front end or at least make sure it's tight.
Drew
Thanks. Will have full upgrade in front suspension including, disc brake setup. Dont plant on dring much at 65 but i using it as a good ref point to size my rear. I live out in suburbs so 55-60 is good driving speed.
1951 Chevy 3100
Riding in the Passing Lane
The 216 wont pull that much gear. Your o-drive will be worthless except down hill.
1972 Chevy c10 Cheyenne Super
Went back to recheck my numbers.
The 216 engine has max torque at 1500 rpm. So, using 2.41 or 2.56 gears gets me right around 1500 rpm. So, does this look like the right rear??
1951 Chevy 3100
no - if most of your driving will be slower speeds, you'll need more torque at the lower RPMs than that gearing would provide, and as George said, no point in an OD with that ratio
Thanks for feedback and patience.
Local rear for sale with 3.73 gear. Looks like this or a 4.11 will get me to crusing speeds of around 60 mph??
1951 Chevy 3100
a 3.73 and OD 5th gear will get you cruising 70 or better, if it's not uphill
thank you all. Im picking up the 3.73 on Saturday.
1951 Chevy 3100
