0 members (), 110 guests, and 4 robots.
Topics128,183
Posts1,057,264
Members48,467
Will my 250 fit with my radiator in the stock location ( 3800 JS code), or will i have to move it to the front side of the core supportand just bolt it in from the front side. My measurement says it will be close.
Thanks ahead of time
Mitch
what's "close"? the fan should be no more than about 1/2" or you'll need a shroud
Couldn't get a fan on my 250 in a 3100, so I put a "new" junkyard electric fan on the front of the radiator. With the water pump pulley and no fan blade there is about a 1/2" between the radiator and pulley. I am using the stock trans and rearend-FYI
Picasa albumn link - a few picks of the new 250 engine mounts
....David
I put a 292(same length as a 250) in a 40 pass a few years back without moving the radiator. There are at least three lengths of water pumps I found that will bolt up to that engine. I used the shortest one I could find along with a flat faced flex fan.
My Blog
Is there a chance that I could press the shaft deeper in the impeller( I did that on a small block when I put it in a 34 ford), and cut off the excess?
thanks for the info
keep it coming you won't hurt my feelings take all the info I can get.
LMD
