10 members (MickeyP, MRMEROTH11, Gdads51, TexasJim50, 2-Ton, Southerntruck, Ponchogl, JW51, Shaffer's1950, 1 invisible),
133
Mod | | | Forums66 Topics128,132 Posts1,056,383 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2002 Posts: 7 Member | | Member Joined: Jun 2002 Posts: 7 | I'm trying to switch a front drum setup to disc without blowing $800 smackers.Which is twice as much as I paid for the whole truck.What 5 lug rotor/spindle setup bolts on to a'66 C10 truck? Which chevy car or truck can I yank them from at my local pick n pull o Stovebolt masters!!!Your wise words of wisdom would be greatly appreciated. | | | | | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | Hey Jed-go to your neighbourhood boneyard and lay your grubhooks onto a set of spindles/rotors/calipers from a 1973-1987 Chevy or GMC half ton pickup. You will switch your original upper and lower balljoints for whatever year of replacement spindle you use and the spindles will just bolt on. Unfortunately the tierod shaft taper where they go into the spindle is not the same from your old style tierods to the newer spindle. I believe that you could get around this by replacing all of your steering linkages with the newer type ones (tierods, centerlink, idler arm). Hope this helps, Jed. Wannabe
"Don't expect anything and you'll never be disappointed"
| | | | | Joined: Jun 2002 Posts: 7 Member | | Member Joined: Jun 2002 Posts: 7 | Muchos gracias Wannabe Advance D for the words of wisdom.Now I know what to look for at the pick your part this weekend,my eyes have seen the light brother!You are a Stovebolt Master.Adios amigo. | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Look for a 71 /72 chevy half ton. It has direct bolt in ,worked on a buddy1s 63 suburban.It also has 5-lug chevy car bolt pattern for the wheels.
| | | | | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | As Mechaniac says, jed....as Mechaniac says. There I go agasin quoting from the, ahem "all knowing magazine world" and letting my mouth get my a$$ in trouble... Let us know how your swap works out Jed. This will be a valuable addition to the "non-stock" portion of the forums. Wannabe
| | | | | Joined: Jun 2002 Posts: 7 Member | | Member Joined: Jun 2002 Posts: 7 | Thank you Mechainiac for the Stovebolt wisdom.Thank's again Wannabe Advance D.I'll let you gent's know how everything turns out.I'm going hunting at pick n pull for rotors and spindles,your words of wisdom will act as my compass,thanks for pointing me in the right direction Stovebolt Masters! | | |
