| | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 65 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 65 | Hello folks, I just got a rebuilt gauge cluster for my '49 GMC 1 ton w/ a 228 engine. The original temp gauge didn't work, and the previous owner just stuck a modern after market temp gauge under the dash. It's probe runs to hole way up near the water pump. The rebuilt temp gauge I got comes up about 18" short. I noticed there are 2 threaded plugs in head near the firewall that the new probe could reach. They are not willing to unscrew too easily, so before I bust knuckles to get one out, does anyone know if they are for temperature probes? Where is temp probe supposed to go? I got it from Jim Carter and the offered to lengthen the probe tube for me, but I would rather not have to pull the gauge out again/ship back/reinstall. Thanks in advance for any ideas or suggestions! Greg
1949 GMC FC253 - 1 Ton Dually 1966 Buick Wildcat Convertible
| | | | | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | Greg In your '49 GMC the temperature sensor was probably an electric one mounted in the thermostat housing as shown in this photo. '49 temp sensor In my '52 the temperature sensor is a mechanical bulb that is mounted in the cylinder head. It is located behind the carburetor in this photo. '52 temp sensor The bulb screws into a bushing that is screwed into the head. Most of the vendors carry this bushing if you don't have one. | | | | | Joined: Sep 2011 Posts: 65 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 65 | Huck, Thanks for the very useful info. The original broken gauge did have wires coming from it, so now it makes sense why. Does that threaded bushing have a common name I can ask/search for? Is it common to a hardware store, or is it mostly old truck related? Thanks again!
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | get one from carter. while your waiting for it to arrive heat up a pan ful of water and drop a thermometer in the water along with the bulb and slowly raise the temp of the water to 180-200 to see if the bulb somewhat matches your thermometer. while your at it, drop your thermostat in too and observe its operation in regards of temp with the bulb and thermometer from closed to fully open. it will keep you from guessing later. | | | | | Joined: Sep 2011 Posts: 65 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 65 | 51 Ashton, I see the part on Jim Carter. I think there actually is one already in the truck being used with the existing gauge. I'll have to take it out and see how it fits with the new one, and if it fits in the head. Good advice on doing a controlled test with the 'stat and new gauge - thanks for that one! Greg
| | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | HI
Just remove the sending unit and adapter from the thermostat housing. Use a 1/2" drive 6 point socket to remove the adapter.
Remove the pipe plug from the head just behind the carburetor. Use a 1/2 drive square socket (4 or 8 point) to remove the 3/4" pipe plug.
Use the pipe plug, to plug the hole in the thermostat housing and reinstall the adapter in the hole in the head. Both are a 3/4 inch pipe thread.
Then connect you new Temp gauge sending unit/probe to the adapter behind the carb.
Good Luck, GMCPic
Dance like no one is watching, Sing like no one is listening, Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420 1948 GMC FC253 1t Factory 80"x9' Flatbed Dually 1948 Chevy COE 2 Ton 8'x15' Flatbed 1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton Cab and Chassis 1942 Clarkator 6 MILL-44 Heavy Aircraft Tug 1942 Ford (9N) Moto Tug with 1/2 yard Loader 1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
