| | | Forums66 Topics128,031 Posts1,055,435 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 134 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 134 | anyone of you know how to remove that pin that holds the lever and spring to put the shifter in reverse....
I like fixing stuff.
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | wow that is a whole lot of no information, what are you working on, what year, things like that. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | check the title brokenhead, it's a 1941 4 speed - sounds like katrina wants to remove the reverse interlock thumb lever from the floor shifter ..... I fergit myself  Bill | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | when I first looked at it it only said shifter spring, notice the edit. I couldn't have answered before it was written. But now that I do know that, I don't know about that.
| | | | | Joined: Aug 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 127 | I'll look at mine later today and let you know, i've done it before, just cant remember off the top of my head. | | | | | Joined: Mar 2010 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 64 | Katrina, I just took mine off today to replace it, the spring. It is a rivet you have to "dremel" the rivet off, no other way. Do it from the botton side, hit it with a punch, out she comes. You will not be able to re-rivet so just plan on adapting something to reconnect it. doug | | |
