0 members (), 61 guests, and 7 robots.
Topics128,021
Posts1,055,355
Members48,420
#857833 06/10/2012 1:04 AM
anyone of you know how to remove that pin that holds the lever and spring to put the shifter in reverse....
I like fixing stuff.
katrina #857836 06/10/2012 1:14 AM
wow that is a whole lot of no information, what are you working on, what year, things like that.
check the title brokenhead, it's a 1941 4 speed - sounds like katrina wants to remove the reverse interlock thumb lever from the floor shifter ..... I fergit myself ohwell
Flxible #857869 06/10/2012 4:04 AM
when I first looked at it it only said shifter spring, notice the edit. I couldn't have answered before it was written. But now that I do know that, I don't know about that.
brokenhead #857894 06/10/2012 12:40 PM
I'll look at mine later today and let you know, i've done it before, just cant remember off the top of my head.
Hotrod_A #859669 06/16/2012 9:06 PM
Katrina, I just took mine off today to replace it, the spring. It is a rivet you have to "dremel" the rivet off, no other way. Do it from the botton side, hit it with a punch, out she comes. You will not be able to re-rivet so just plan on adapting something to reconnect it. doug
