6 members (klhansen, walterhvogel, Barry Martak, amtrakjoe, GusG, 1 invisible), 71 guests, and 3 robots.
Topics128,089
Posts1,056,419
Members48,443
Junior Member
Junior Member
I am looking for a new cast iron distributor gear for 261 engine. Any leads would be greatly appreciated.
Thanks, Bill.
Bill in Colorado
You might try Langdon's Stovebolt. Tom may have one he'll sell you. Get his site through the Links tab.
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
The gear is the same as for the 235, it should be pretty easy to find.
Paint & Body Shop moderator
GM parts book lists the same gear, 38-62 all 6 cylinder engines, part number 1929578. Although I remember reading GM switched from steel camshafts to cast iron cams in the 6's around 1955, and the cast cam is supposed to use a different gear.I used to modify later 250 Chevy 6 HEI distributors for use in 235-261 or GMC engines,I've kinda forgotten, but I believe the 250 gear worked fine on the old 6's.You can buy a whole distributer on Ebay, they show up from time to time or search the Swap meet here on Stovebolt, there a few guys on there that have a supply of distributors.
