| | | Forums66 Topics128,088 Posts1,056,413 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#85774 01/30/2004 6:15 AM | Joined: Jan 2004 Posts: 6 Junior Member | | Junior Member Joined: Jan 2004 Posts: 6 | I am looking for a new cast iron distributor gear for 261 engine. Any leads would be greatly appreciated. Thanks, Bill.
Bill in Colorado
#85775 02/13/2004 11:36 AM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | You might try Langdon's Stovebolt. Tom may have one he'll sell you. Get his site through the Links tab. | | |
#85776 02/16/2004 6:14 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The gear is the same as for the 235, it should be pretty easy to find.
#85777 02/16/2004 1:07 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | GM parts book lists the same gear, 38-62 all 6 cylinder engines, part number 1929578. Although I remember reading GM switched from steel camshafts to cast iron cams in the 6's around 1955, and the cast cam is supposed to use a different gear.I used to modify later 250 Chevy 6 HEI distributors for use in 235-261 or GMC engines,I've kinda forgotten, but I believe the 250 gear worked fine on the old 6's.You can buy a whole distributer on Ebay, they show up from time to time or search the Swap meet here on Stovebolt, there a few guys on there that have a supply of distributors. | | |
