1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | My brake petal is so high I have to raise my foot about 10" to press it. My thought is to cut a few inches out of it. Is there some warning anyone wants to give on this?
~Jim
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I would look at any and all other options before I cut into the one lever that will stop the truck. A panic stop might just just put too much pressure on your new weld and brakes may not brake after the pedal breaks.  | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Jim,,this is something I've been contemplating myself. I assume you've upgraded to a more modern dual circuit M/C?
The pedal pad is simply welded to the top of the brake arm so shortening it shouldn't compromise its strength,assuming it's welded back on properly. I'd imagine the main thing to watch is that the pedal doesn't bottom out on the floor before its reached it's full range of travel. I'd make very sure the pedal stroke is properly adjusted and that you're happy the system is fully bled before considering any modification.
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Ive done it to several trucks. It makes it much more comfortable to drive & looks better. Safer too. The master cyl may not get clear to the bottom but if it goes down that far you are in serious trouble already. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | The pedal stroke was designed that way for a reason. It gets the master cylinder piston all the way to the end of its bore, if necessary. If you change it, be aware your epitapth might need to read "Too lazy to lift his foot"! Jerry
| | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | i'd listen to jerry.......dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Maybe its just us guys who have changed over to the dual m/c's as it seems most of us have the same problem. In fact, mine is the same way and much higher than orignal but then mine is not original. I need to cut about 1 to 1 1/2" off mine and I'm planning on doing it. I'll weld it up but I plan to drill two small holes and put a couple roll pins in "just in case". The aftermarket pedal arm is plenty thick and wide = strong. Jerry, I'm not to lazy to lift my foot.... the cotton picking thing is just to high after getting it all set up  and I promise, its not going to run out of pedal before it gets to the back of the bore.....but good advice everyone. | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Just pulling your chain a little- - - -if it's not running the stock M/C, you've probably got a little fudge factor to work with. You need to be aware, however, that in case of a failure of one end of the dual system, the pedal goes more than halfway down before the remaining system starts building any pressure. The two pistons inside the master cylinder bore have to make physical contact to make up for the fluid loss between them. On a system engineered to work that way, the pedal will be within about 2 inches of the floor before any stopping happens. Be sure you take that into account before reducing the pedal stroke. A mistake in geometry could get deadly! Jerry
| | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | HotRod, I've recently upgraded to a dual MC on my 52' 1/2 ton and noticed that the pedal gets almost to the floor to stop the truck. Does 1 reservoir apply before the other in a dual MC? Since the new dual MC is turned backwards, I ran the outer port (front port) to the rear brakes and the closer port(rear port) to the front brakes. Thanks | | | | | Joined: Aug 2011 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 45 | Hmmm. The front port of a master cylinder is always the port closest to the pushrod, and always goes to the frt brakes. Check for the pedal height off the floor when a bleeder screw for both the frt and back are open, and fluid bled off. You should have about 1 inch of clearance off the floor. Then figure out how much you can safely shorten the pedal.Also, most vehicles have a pedal stop, to keep it from coming up to high, but still have some play in the pushrod to the piston in the master cylinder.
The older I get, I only want to work on older rigs.
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | The larger-volume reservoir needs to go to the disc brake system because it takes a lot more fluid to make the large caliper piston move, and there might not be enough fluid to compensate for pad wear if the small chamber is used. The smaller of the two chambers will handle the smaller-volume wheel cylinders of the rear drum brakes. If it's got equal-volume reservoirs like some of the early drum/drum systems had, front to rear hookup won't matter as long as the drum system plumbing gets a 10 pound residual pressure valve. 10 lbs. on a disc caliper will make the brakes drag. It's needed on a drum system to keep the fluid pressurized against the tension of the shoe return springs.
As long as there's a full column of fluid between the M/C pistons, they will move together as the brake pedal is pushed. It's when the fluid between the two pistons leaks away, or air gets into the system that pedal height becomes an issue. Jerry
