| | | Forums66 Topics128,162 Posts1,057,040 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 6 New Guy | | New Guy Joined: Jun 2012 Posts: 6 | Hey everyone. I'm new to the forum, and have a question I thought you guys might be able to help with. I recently bought a 1966 K10, but quickly learned that something wasn't right. The cab was from a C10, and I can't figure out exactly what the frame is from. It had an old gas line going to the rear of the frame, it has short frame extensions riveted to the rear of the framerails, and the radiator support brackets that are riveted to the front of the frame have rubber mounts in them, rather than the solid ones I see on the K10s. From the partial VIN, I know its a 66 Chevy, and I know that 66 suburban E-brake cables won't fit it. Could it be from a panel truck? I would have thought that panel trucks would have the same E-brake cables as suburbans? Thanks for any help you can give me. Charlie | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Sounds like a suburban frame. Dunno about the cables, 66-72 was different ebrake setup than 63-5. | | | | | Joined: Jun 2012 Posts: 6 New Guy | | New Guy Joined: Jun 2012 Posts: 6 | Thanks for the reply. Also, when the PO put the pickup cab on it, they added some rear cab mounts a couple of inches behind the original ones on the frame, and about 1 1/2 inches higher. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Do you have any pictures of the suspect frame? | | |
