5 members (Ponchogl, gswbbc, Robert Crandall, Opelika Tom, 1 invisible), 88 guests, and 2 robots.
Topics128,037
Posts1,055,463
Members48,422
#839675 03/29/2012 6:53 PM
My 53 half ton came without the outer grill strips. The rest is intact. I came across the pieces I need but in order to install them, it looks like I need to remove the radiator, pull the existing grill and attach the new strips and reinstall the unit in one piece. The engine is still in place. Is there an easier way? Thanks Steve
I'm not sure if this will help or not, but it's pretty easy to just remove the front clip. 7 bolts on each side, 2 top supports and 2 bolts on the front bottom. The advantage is you can set the front clip on saw horses and get other things cleaned up while it's off.
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
No need to pull the radiator
...link...
Maybe the pics above will help
DMGfifty #839749 03/29/2012 11:25 PM
Well, that sure sounds a lot easier than my idea! Thanks, Steve
DADS50 #839755 03/29/2012 11:37 PM
Thanks for the great pics. This really makes it easier to understand. Like they say, a picture is worth...well you know. Steve
53Movinon #857082 06/06/2012 10:22 PM
Good reference and great pics
Your not trying hard enough if you don�t screw up every once in a while.
52 1/2Ton 235
