| | | Forums66 Topics128,089 Posts1,056,144 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 4 New Guy | | New Guy Joined: May 2012 Posts: 4 | Hi all. I'm new to this forum (and my 57 Chevy 6400 Dump) and am looking for your expertise and advice. My "new" truck still has the original 6 volt system and I'm told I should update to 12. The battery is an old 12 volt I assume installed just to sell the truck and needs jump started to run the truck. So...I guess my question is this. Is it worth it to update to 12 volt. Approximately how much am I looking at spending and what components need changed other than the generator and starter? I intend to use the truck in my business but will restore it first before I put my business name on it. Other than a carburetor rebuild it runs quite well. Thanks in advance for any input.
Mark | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1955 started 12 volts in Chevs, so no conversion needed.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: May 2012 Posts: 4 New Guy | | New Guy Joined: May 2012 Posts: 4 | Guess I showed my ignorance real quick then. Was told it a 6 volt system since it has a generator. 2 things I hate (1) Plumbing. (2) Electrical...other than welding that is. Ok, 3 things. (3) Bad information to make me look stupid  I saw a You Tube video (from this forum) on swapping out a 235 generator for altenator. Mine has a 261. Any idea where to get a mounting bracket like the one on the 235 video? After this I'll pester the guys in the carburetor  | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | A generator was used up to 1962, maybe some 63's.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Mark, Welcome to Stovebolt.com You'll be amazed by what well meaning people advise you about these old trucks. "Those flathead engines were great." If you have not done so already, get a 1957 Shop Manual, Operator's Manual, and wiring Diagram ( type [i][b]1957[/b][/i] in the Search Box). This is a large Specifications Manual that has a large amount of information on all 1957 model trucks (it is a large file to download). | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | You can get this bracket at Classic Parts Of America. alternator bracket You can also get a shop manual for truck,they're very useful.I believe you will want the 1957 shop manual . manuals You can also look a these manuals online at Old Online Chevy Manuals look under Chevrolet Shop and Repair Manuals. Tim Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Before you jump into switching the gen for an alternator, take the generator to an auto electric shop and have it tested. May just need brushes. A local shop charged me $65 for new brushes. Works perfectly. You can replace them yourself and save, but sounds like you have a lot on your plate with your new truck. Or could be a problem with the voltage regulator. Here are some Stovebolt posts regarding voltage regulators ... > Post 1> Post 2Don't "hate" wiring. It's about as simple as can be. Juice goes in one end of the wire and comes out of the other. Just track the wire and see where the juice flows. Keep asking questions on the Stovebolt. There are some really good auto electric guys here. Good luck.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: May 2012 Posts: 4 New Guy | | New Guy Joined: May 2012 Posts: 4 | All, Thanks for the feedback. I will be ordering all available manuals for the truck before I begin any work. Main things to do are replace leaking seals, rebuild carb and body work. As far as the generator, it's operating just fine (I assume) but I again was informed to update to alternator. Not sure why. By the reply, I'm assuming I should keep the generator instead. The battery is 7 years old and I know it needs replaced. Thanks again guys.
Mark | | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | It is not something you have to do. I swapped mine cause I was using more electrical stuff then the generator could handle Such as electric fans and what not. Run it as long as it works for you.
Good luck. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Mark,
You are doing the right thing by asking here about things you were informed. If the same person who suggested that you change to an alternator is the same person who suggested you change from 6v to 12v, you should be wary of further suggestions (just listen politely and do as the British do in such situations, just give a friendly/polite nod and say "indeed").
GrandpasTruck has the right response. If your generator is working fine and you do not need more amps, stay with the generator.
| | | | | Joined: May 2012 Posts: 4 New Guy | | New Guy Joined: May 2012 Posts: 4 | I'm off to get a new battery and carb kit tomorrow. Ordered all the manuals I could find on Classic Parts on-line. Thanks again gentlemen. | | |
