2 members (Peggy M, Simso),
291
9
Mod | | | Forums66 Topics128,077 Posts1,056,034 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 14 New Guy | | New Guy Joined: May 2012 Posts: 14 | I wasnt sure what section to post this in? Anyway,does anyone out there know of a good anti theft device? I was thinking of the "truck club" or this "pedal jack".Anyone have any experience with either one? | | | | | Joined: Feb 2000 Posts: 268 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 268 | Fuel Cutoff, Coil ground, large logging chain locked to power pole... move to someplace with a lower crime rate. | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | A Smith and effin Wesson ought to at least slow 'em down a bit.:)
But an electrical cutoff switch in the cab is cheap and easy. But use a quality switch like a Cole-Hersee (made in Massachussetts)not the typical plastic key under the hood nonsense. A fuel cutoff, like Jolley says, is cheap an almost as easy.
Fabbing up some sort of interior hood release would be tough, but might keep that rare oil bath air cleaner with the truck. (I was Barrett Jackson in '04 and a note on this guys " super high end 'Cuda, was offering a $1000.00 reward for info on who stole his rare original air cleaner-and this was from a car that was in the "secure" high dollar tent with cameras and security, so imagine the fun that be had under your hood at the Home Depot!) | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | Years ago I had a telescoping double hook device that hooked around the brake pedal on one end (pulling up) and around the steering wheel spoke (pulling down) on the other. This prevented steering and braking as long as the device was in place. It had a key like a Coke machine lock- round. It was easy to store, between the seat and door, when not in use. It was fast to put in place and remove. I could see it working fairly well with Stovebolts. This one is somewhat similar (but with the hook directions swapped from what I had.) Bill | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | I had a dummy coil wire, just an open small rubber hose with the regular ends, looked like a real coil wire.... Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | | | |
