| | | Forums66 Topics128,196 Posts1,057,396 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#85533 08/30/2004 12:47 AM | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | I found a nice gauge cluster in a GMC AD in the local juckyard. I needed the 60 psi oil pressure gauge for my new 261 but left ammeter and gas gauge because of the polarity difference between the GMC and my '48 Chev.
Can the ammeter and gas gauge be used with some tricks, such as wiring things up backwards?
(If I go back and get the rest, I'll bargain them down because some idiot already took the oil pressure gauge!) 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#85534 08/30/2004 2:37 AM | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | Just switch the wires on the GMC ammeter to use in a Chevy truck. Note that the background color and needle colors are different than Chev.
I don't know about the gas gauge, but should be the same deal..........
*** GMC ***
#85535 09/03/2004 8:09 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Just a note- the '54 chevy oil pressure gauge has the same guts but a differant back (and 60 psi) as the earlier gauge. I just drilled out the rivets on mine and riveted the old face on the new gauge, and didn't have to repaint the needle.
I don't know if the gas gauge will work or not. If it has a permanent magnet in it it may deflect the wrong way, but it won't hurt it to try it out if you keep it below 6 volts.
