| | | Forums66 Topics128,132 Posts1,056,386 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 66 | Hello, not sure if this is in the correct area but my truck is a street rod. So here goes, does any one have thier spare tire mounted to the outside of the box on the riders side in front of the the rear fender? My truck is a 37 and I've got a original spare tire carrier for that location coming. If so, could some photos be sent? Thank you, Al | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | APV 60 - I have never seen a spare tire carrier on the side of the bed in front of the left rear fender, but have seen a few pictures. There is enough room to mount the tire on a carrier in that spot without the dimple in the fender. I think you will probably find when you take all of the surrounding things into consideration - the door opening, the fender and the height that you will have to mount the carrier, it will be down to a few inches one way or the other - not too close to the fender, snug as possible to the bed and enough clearence from the door with consideration to someone who would be entering the door. Where did you acquire the mount? Just curious. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Dec 2009 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 66 | Hello Joe, I found the carrier form a fellow street rodder in Tooele,UT. He sent me photos of it mounted on a 37 0.5 ton truck he is building. He is in the process of cutting it off the box and then bead blasting it for me. It my not be original but it was spot welded to an original 37 box on the riders side in front of the riders rear fender. There does not appear to be a fender dimple for it. Al | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I bought mine from a used parts place in Arizona, I can't remember the name.
~Jim
| | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | Mothertrucker's, Big Chevy? | | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | my spare tire carrier on my 37 is under the rear of the bed though i am going to be discarding that "new gas tank is going in that location" not sure when i am going to be getting to that but your welcome to it after i get it out
1937 1/2 ton
| | | | | Joined: Dec 2009 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 66 | Thank you but my new gas tank is where the spare tire was. Al | | | | | Joined: Sep 2011 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 54 | Hey guys - I have a 37 as well and was thinking about putting the tank back where the spare tire carrier originally went. What tank did you guys use and how did you mount it? Has anyone used the original tank and just relocated it? Haven't measured yet. | | | | | Joined: May 2010 Posts: 303 Shop Shark | | Shop Shark Joined: May 2010 Posts: 303 | | | |
