1 members (moparguy), 80 guests, and 0 robots.
Topics128,151
Posts1,057,000
Members48,460
I installed fenton headers and painted the engine on my 46 chevy truck. But know I dont know who to put the linkage back together.
Does anyone know where they sell these parts new?
Deos anyone know where to get the piece that locks the
Pleae help
1st Attemp to install
Connector with missing fastner.
Linkage Parts
1946 Chevy Truck Export Blue with Black Trim
Here is a pic of the keeper on my truck
...pic...
I would think you can find that clip at a good hardware store or carquest or a napa.
There are some pics in this thread
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=854121#Post854121
I don't know if it will help because its not a Fenton set up.
Can you post a pic of that side of your engine?
The linkage connector is called the "Keeper"?
...pic...
Does anyone have a good picture of what the clip looks like?
...click...
Found these hair pins at lowes that work great and were just $0.68 smile Thanks for everyones help, now time to install it
Hair Pin
Linkage with hair pin
It looks the the rods are in the wrong spot in that pic
Try switching them
Good luck
I got the swivel on, but now I am having trouble connecting the linkage rod from the carb to the swivel. Has anyone installed the carb and gas pedal linkage on a 58 235 motor with Fenton headers?
Does anyone have a picture of how the linkage rod should be bent to work with the headers?
Swivel
Carb Linkage
Has anyone ever used the install kit for fenton intake from chevsofthe40s? Can I use this instead of trying to modify the stock linkage rod?
Install Kit for Fenton Intake
Bumb
Bump
What is your problem with the linkage?
1949 Chevy 1/2-Ton ~ Red Truck
More pix on Photobucket
It doesnt fit with the Fentons installed
Sometimes you just have to bend the rods and bend again to get it right. Might even have to make a new rod. Trial and error.
Drew
