4 members (Stovebolt48, Steelonsteel, Bill Hanlon, lumbersawyer), 31 guests, and 2 robots.
Topics128,037
Posts1,055,466
Members48,422
#854475 05/27/2012 7:40 PM
What tool can I use to turn my engine over. I can access the slot in the harmonic balancer through the grill, but nothing seems to work.
It's not the weight of the load, that breaks your back. It's how you carry it.
Riding in the Passing Lane
If the engine has been running recently & is not real tight for some reason you can grab the fan blade & belt at the same time & turn it. If its been setting & is hard to turn you can get under it & remove the flywheel cover & use a large screwdriver.
1972 Chevy c10 Cheyenne Super
