5 members (32Fordpuchoptop, treegrower, Jon G, Danielbolt, 1 invisible), 194 guests, and 3 robots.
Topics128,078
Posts1,056,053
Members48,433
#853060 05/21/2012 6:43 PM
I have a 54 1/2 ton with a 235 ID number 0952888F54M matched up to a HydraMatic ID CH54 7968.
Can someone decipher these numbers as to build date/and serial number? It appears from what I've read here the 09 means Sept. and 52 is the year, but that doesn't make sense if it's a 54 built in 52.
Any ideas? Thanks. Jim
1953 Chevy 3100 3 window
1997 VW Rialta Motorhome
2011 Fusion
Jimbar #853119 05/22/2012 1:03 AM
I believe the F54 means "Flint Michigan, 1954". The "54" in the Hydramatic number seems to confirm that, also. It appears that you've got the original engine and transmission that came with the truck.
I get some of the deer I take from my farm processed by Stone's slaughterhouse in Lynnville. They've been processing beef and venison for me for about 25 years.
Edit: according to the chart below, F54M indicates the engine was built in Flint, and installed in a 3100 truck with an automatic transmission. The original transmission would have had an orange-colored tag on it.
http://chevy.oldcarmanualproject.com/chevyresto/54057.htm
The build date will be a code cast into the side of the block, something like B 25 4.
Cletis #853159 05/22/2012 3:39 AM
Block casting number is 3835913 with GM19 behind it. The whole truck is not a 54,
just the underparts. Cab and tin is 53. It fit right on the chassis.
Got tired of the point ignition and ordered a Pertronix 1168LS today. Jimbar
2011 Fusion
Jimbar #853210 05/22/2012 10:10 AM
Jimbar,
That is a 1954 head casting code.
Here are locations of head and block [b]date[/b] casting codes.
It looks like you have converted to a 12v electrical system.
I found H 11 4 down by the starter and figure the engine was built Aug 11, 1954. The 54 stuff was already changed to 12 volt, so I kept it. I had one of the old Pertronix units when I had the 53 frame under it maybe 20 years ago. It worked fine. Thanks to you guys for all the help.
Jimbar, retired Navy Chief Any more of us out there?
2011 Fusion
Jimbar #853332 05/22/2012 9:07 PM
That is the correct interpretation of the date code.
