| | | Forums66 Topics128,132 Posts1,056,383 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 9 New Guy | | New Guy Joined: May 2012 Posts: 9 | Hi all, I'm a newbie member but have been using great tips from the forums for the past year. My '55 235 has been apart since last August and I'm finally starting to put it back together. Two questions about rods: 1) Upon assembly, are the wrist pin pinch bolts oriented toward the camshaft side of the engine or the non-camshaft side? and 2) What are the pinch bolts supposed to be torqued to? I've read before that the shop manuals say they're supposed to be "tightened" but don't give a value. What do experienced engine builders torque them to? Thanks in advance for your help, Dale | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Your answer is on this page. Engine assembly This is for 55 2nd but I don't believe the information changes. I believe that your pistons have a proper front and back orientation to them. | | | | | Joined: May 2012 Posts: 9 New Guy | | New Guy Joined: May 2012 Posts: 9 | Terrific! I've added the shop manual to my favorites for future reference. That clears up the connecting rod orientation issue. Any experienced builders have any recommended pinch bolt torque value? Thanks in advance, Dale | | | | | Joined: Feb 2004 Posts: 29,813 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,813 | I believe the bolt is a 3/8"-24 which would be tightened to 30-35 ft.-lb. or so. Be aware it's possible to put a twist in the connecting rod while tightening the pinch bolt if the rod is held in a vise while the bolt is being tightened. Find a pin punch that's a close fit into the hole in the wrist pin, clamp it into a vise, and slide the pin over the punch to anchor the piston/rod assembly while the pinch bolt is torqued. Jerry
| | | | | Joined: May 2012 Posts: 9 New Guy | | New Guy Joined: May 2012 Posts: 9 | | | |
