Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (crenwelge, Peggy M, Wayne67vert), 195 guests, and 6 robots.
Topics128,282
Posts1,058,494
Members48,490
#852876 05/20/2012 7:14 PM
my gm factory hei dist has the following i.d. stampings on it.1103274 7m20 anyone out there know what they mean?
As far as I know, the distributor bodies are all the same. The 7M20 is what differentiates the application. I'm taking a stab here but my educated guess is the 7 stands for a 7 pin ignition control module. The control module, springs and vaccuum advance are also different from applications to application. Maybe the M20 refers to that. ????? Anybody else?
makes sence,i'll take a look at module to see if infact there are 7 pins.stand bye
i found a 4 pin module inside.maybe a 7 belongs in there or did at one time.but thats what i found.
