2 members (Tstan7, Napco Mark),
75
Mod | | | Forums66 Topics128,022 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 66 | The other day the outside temps pushed 90 degrees. My '59 Truck w/ a 261 went up to 190....is this getting too hot? What do you think will bring it down? This engine was rebuilt this spring and has been running great. Normal everyday driving in "cool" weather has the needle at 180. Do i need to be concerned? Thanks as always for any info!!  | | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | Plain water boils at 212 degrees. A 50/50 water/antifreeze mix boils at a higher temperature. Coolant under pressure boils at still a higher temperature. What is there to worry about if coolant level is adequate. My opinion says you have some room before your system boils.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | assuming you haven't gotten many miles on it yet, keep in mind a fresh rebuild can run a little hotter than a well worn in one ... doesn't sound like a cause for worry .... yet
Bill | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | That cooling system was probably designed to run a 7 Lb. pressure cap, which would let it boil at 233 degrees F. with plain water. A 50/50 antifreeze mix would probably take it to 240 or so as long as you have a good pressure cap and no leaks in the system. I think you're going to be OK unless it starts going to 200+ regularly. Jerry
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | As long as it stabilizes, there would be no problem that I can see, I prefer to have my engine run at least 180-190 deg. I used to run a 195 degree thermostat, but when I took the engine apart it seemed to have walked off. I used 195 degree in all the old engines. But now that my driving cars are modern, I don't even know what temp thermostats are in them. The gages have no numbers and I have never replaced one in my new cars. So, No it should be fine. Oh and by the way, am I the only one that is wondering why there is no degree symbol on the keyboard? Do they make keyboards for mechanic typing? | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | 195's didn't even exist when these engines were new. Engines running alcohol-based antifreeze got a 160, and engines with "permanent" (ethylene glycol) antifreeze got a 180 stat. 195's didn't come out until after the clean air act of 1968 when it was determined that hot-running engines with 14# radiator caps ran cleaner and warmed up faster to minimize air pollution during the first few minutes of operation. I can see no reason to run a 195 thermostat on any stovebolt engine unless it's running tight-clearanced hypereutectic pistons and other reduced clearances and super-thin oil like a modern engine. Jerry
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | there is no degree symbol on the keyboard
Do this: 1. press and hold the "ALT" key 2. press "0", "1", "7", "6" on the numeric keypad | | |
