1 members (klhansen),
101
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,151 Posts1,056,999 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 83 | I'm installing a bed on my 1941 3/4 ton, and I'm not sure where all the cross sills are supposed to be located. The 1st and 2nd sills counting from the front are pretty obvious because of the mounting holes in the frame. The 3rd and 4th sills are not as obvious. Could someone please give me either the measurement of these sills from the front panel, or since the sills match up with holes in the bed strips, give me the number of holes back from the front panel. I've looked on the Mar-K website and searched this forum with no luck. Thanks! | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I will be able to measure on my 3/4 ton this weekend, if someone else hasn't given you an answer by then. | | | | | Joined: Nov 2010 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 83 | Thanks 46. I think I've got it figured out. Appreciate the help though. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | No problem, just PM me if you end up needing any measurements. I will be turning it into a shortbox within the next month or so though. | | | | | Joined: Jun 2009 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 25 | Does anyone else have the measurments for the cross sill locations? I need them for my 1941 3/4 ton pickup. I pm'd 46gmcpu and summerfi with no luck. Thanks.
Dan | | |
